1967 TI box ground wire - NCRS Discussion Boards
  • Richard B.
    • April 1, 2005
    • 80
    There is a ground wire coming out of the TI box...currently mine is attached to nothing. It was probably attached somewhere before i took everything apart and now i can`t make sence of where this ground should be attached to. Can someone look at theirs and give me an answer. Thanks in advance for your help.
  • Rob A.
    • December 1, 1991
    • 2126
    Re: 1967 TI box ground wire
    The ground wire attaches to the front of the radiator support with a hex head screw. If you have the original support and your car originally came with T.I. the hole should be there. If not, the assembly manual shows where the hole should be.
    • Richard B.
      • April 1, 2005
      • 80
      thank Rob....there was the whole just as you said behind the horn. All done with that task..thanks.
      richard
