Water Pump ID? Found nothing in arrchives - NCRS Discussion Boards
    • November 1, 1998
    • 138
    Can anyone id this water pump...
    330819
    L 1 5
    GM
    3
    Its on my '74 and needs replaced, should I hang on to it or is it a general run of the mill replacement?
    Thanks Jack
    Re: Water Pump ID? Found nothing in arrchives
    Casting number 330813 is what's listed as correct for '72-74 SB cars. The date code 'L 1 5' suggests it's not factory original to your car since it was cast Dec 1st 1975. The 'GM 3' simply designates the pump housings casting source, as more than one producing mold/casting site were in use.
      • November 1, 1998
      • 138
      Thanks Jack
      will hang on to it then incase someone may need it...Jack
