amp gauge quivers at idle. 63 - NCRS Discussion Boards
  • Wally A.
    • May 31, 1979
    • 170
    my amp gauge is jumping around and not holding steady only at idle. if i run the engine up over 1500 rpm's it smooths right out. my guess is that my voltage regulator is acting up, is it possible to be the alternator?
  • Mike B.
    • November 1, 2004
    • 389
    Re: amp gauge quivers at idle. 63
    It is very likely the regulator as you suspect. The contact point on/off settings may need to be adjusted for the slower speeds. If you have no other symptoms with charging at any speed, then it is not the generator.
