C1 power top ground - NCRS Discussion Boards
C1 power top ground
  • Garry Barnes
    C1 power top ground
    Can anyone tell me where the ground wire running from the 1956 power top unit in the trunk should be correctly attached? The ground wire is at least two feet long, so I can assume that it is nowhere close to the unit itself. Thanks.
    Garry #18531
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C1 power top ground
    I've seen it go to the tail pipe support hole or the rubber spring cushion bolt
    • Garry Barnes
      Roy, I know that I am not supposed to take up bandwith with such trivial comments as "thanks" but I am old school where I appreciate someone taking their time to share their knowledge with me, so.....thanks!
      Garry
