Re: Valve covers - NCRS Discussion Boards
Re: Valve covers
  • Robert C.
    • December 1, 1993
    • 1153
    Re: Valve covers
    The steel or the alum. covers? Either way , You should be able to buy a rubber fitting that holds the pvc valve. This part is available for a 71up Corvettes. You can drill a hole in the cover, install the rubber gromet, and push in the pcv valve.
    Texas Chapter NCRS
