Muncie experts needed - NCRS Discussion Boards
  • tom444634
    I'm in the process of rebuilding the Muncie in my 71 LS5. Everything was going smooth until I tried to get the front slider gear off. I removed the retaining ring and it won't budge. I even rigged up a jig for the press and tried to press it off but it won't move. I didn't use that much pressure but I would have thought it would come off. I did a Muncie years ago in my 71 SS 454 Chevelle and don't recall having this problem.
    Any suggestions???
  • William V.
    • December 1, 1988
    • 399
    Re: Muncie experts needed
    I've had good success by using a gear puller. I use the press to remove first and second.
    • William C.
      • May 31, 1975
      • 6037
      slide the gear puller behind 3rd gear and pull on the whole batch, the slider hub will be pushed off by third gear.
      Bill Clupper #618
      • tom444634
        AAAHHH, so that is the trick! Makes sense. I'll give it a try tomorrow.
        Thanks guys!
        Tom
