Correct Fuse - NCRS Discussion Boards
Correct Fuse
  • Mike valliant
    Correct Fuse
    Installing all the correct colour coded fuses
    in the fuse block of the 67.All complete except
    for what i believe is the correct 4 amp.purple
    [internal] stripe.Any input will be greatly
    appreciated as to where to obtain.Thanks kindly.
    Mike Valliant
  • Peter L.
    • May 31, 1983
    • 1930
    Re: Correct Fuse
    Mike - I believe you will find that the appropriate color-code the '67 4 amp, 1-1/4" fuse is pink. If it's a Bussmann (stamped BUSS on the side of one of the metal end caps of the fuse) 4 amp fuse, it will have the pink band on the inside if the glass. If it's a Littelfuse (stamped LITTELFUSE on the side of one of the metal end caps and LF on the end of the same end cap), I'd expect to find a pink dot on the outside of the glass. Pete
    • Mike valliant
      Re: Correct Fuse
      Pete,thanks so much for the correction.Although i
      did get some of the information from an archive,looks
      like i was in the right church,however in the wrong pew.
      Mike Valliant
