...equipped with check valves in '67? I have a non-original fuel filter with a sight glass installed between the carb and pump. When I first bought the car, the sight glass was always full and the car fired right up. I notice now that I've got to crank the car longer to start it and, although the tank is full, the sight glass is empty. When I turn the car off and pop the hood, I can watch the gas in the fuel filter sloooooowwwwwly drain back to nothing. At first I thought the metal fuel line(s) to the carb were getting hot enough to cause vapor locking, but they are only slightly warm to the touch, and the fuel doesn't rise back into the filter when the car cools off. If the fuel pump has a check valve that isn't working, it would account for the fuel drainage, or are there other possibilities? Many thanks
Bill Braun
Bill Braun
