71 wiper r/h washer tube?? - NCRS Discussion Boards
  • David M.
    Infrequent User
    • November 1, 2005
    • 19
    how does this run on the wiper arm, from the hose to the spray nozzle? thanks, david
    s
  • Lyle24961
    Re: 71 wiper r/h washer tube??
    Their is a solder joint at the end of the arm and three or four plastic clips.One arm has three clips one has four. E-Mail for more information or help with yor wiper arms.
    Lyle
      One side (RH) loops up over the blade while the tube on the opposite side (LH) points down and 'ahead' of the wiper blade. Both reproduction tubes and plastic clips are available from Paragon. Note: both arms and tubes were painted black and I recommend a torch and silver solder to affix the tubes to the U-shaped cradles at the top of the arms...
      • Kevin G.
        • February 1, 2005
        • 1076
        Hi David, here is a picture that may help. Kevin.
        • Harmon C.
          • August 31, 1994
          • 3228
          Unless that picture is making the bends in the tube it is a poor example.
          Lyle
          Lyle
          • Kevin G.
            • February 1, 2005
            • 1076
            One more picture for you.
            • Harmon C.
              • August 31, 1994
              • 3228
              Much better picture! If I was restoring them I would make the part between the weld and the bend straight and move the top clip away from the other one to a position near the bend.
              JMHO Lyle
              Lyle
