C2 Part # Needed - NCRS Discussion Boards
C2 Part # Needed
  • Michael H.
    • January 29, 2008
    • 7477
    C2 Part # Needed
    Does anyone happen to have a current part number for an engine oil pan drain plug and another for just the gasket? Groups 1.428 and 1.456. Thanks...
  • Eugene B.
    • May 31, 1988
    • 710
    Re: C2 Part # Needed
    Michael,
    Regarding the drain plug gasket: I used a white plastic NAPA universal gasket when I put the engine back together for my '65. It looked like the original but seemed to want to weep for a long time.
    The current gasket from GM is P/N 14090908. It does not look like the original, but it has a great little seal around the hole that should provide a leek tight seal.
    Gene
    • Michael H.
      • January 29, 2008
      • 7477
      Thanks Gene, that's exactly what I needed. I finally changed the oil in the 66 and the drain plug has been dripping about once an hour ever since, even though it's properly torqued to specs. I KNEW I shouldn't have changed the oil ! It's all Dukes fault.
      • mike cobine
        After you change it, you need to DRIVE it. The engine needs to get hot and seal that gasket.
        If you want, since I know you never drive them anymore, I'll volunteer to excercise the '66 for you once a month.
        • Michael H.
          • January 29, 2008
          • 7477
          Hi Mike,
          After a long five year nap, the 425 HP is back "on the road again"! Spent almost a month repairing all of the misc things that happen to cars when they sit for a long time but finally had it out to terrorize the neighborhood again. I've learned a lesson about allowing cars to sit for long periods with todays fuel, especially in the Florida heat. It's just not logical to live in Florida and have a non operating big block Corvette conv in the garage.
          • mike cobine
            I know, that is why I stuck mine behind the shed under a blue tarp. That way I don't have to look at it each day in the garage.
