Rear cross member replacement for 1960 - NCRS Discussion Boards
  • Richard
    I am getting ready to remove and replace the rear cross member of my 1960 frame. I see that it is attached to the main frame with rivets. How do I attach the new rivets to the frame? They are not like bolts that you can tighten with a wrench.
    Also, I was thinking of purchasing the replacement member from Corvette Central. Does anyone have any comments about their frame parts?
    Thank you
  • bob Gaynor #21091
    Re: Rear cross member replacement for 1960
    am doing the same repair. zip products has the crossmember and the rivet kit
    • Larry Allen NCRS #11708
      I used the cross member from Corvette Central and it worked very well. It fit like the original and was easy to replace. I feel sure there is only one primary source for this part, maybe even GM. I had a local machine shop do the job while the frame was bare, they replaced the rivets just like the factory.
      • Ted L.
        • May 31, 1999
        • 101
        Richard,
        I had to replace mine also. Got it and the rivets from Zip. It takes rivets at the rear but is welded at the front. I was able to re-rivet the new one by heating with acetylene and using a big hammer and then MIG'ed across the front. How's your battery box? I had to replace it too.
        Ted Lake
