under carriage detailing - NCRS Discussion Boards
  • Ron Gaal
    A little more specific to my question,I am refering to the black paint on the frame and other parts. Thanks
  • Dennis A.
    • April 30, 1999
    • 1010
    Re: under carriage detailing
    Ron...
    Best tool in my garage for touch-ups is an Airbush, aluminum foil is easy to use for masking around the area you are going to touch-up. As with all touch-ups, getting the paint to match takes some luck, spraying some chips with a hole in them and overlaying the sprayed chip on to your frame will give you an idea if you are close to a match.
    Good Luck
    • Ron Gaal
      thanks for all the suggestions.
