C1 NOS Replacement Trico' for my '56 - NCRS Discussion Boards
  • steve westphal
    Shouldn't there be a left AND right wiper arm in my set? I think they are Rplacement NOS arms but both are angled the same when placed one on top of the other. Thanks!
    Re: C1 NOS Replacement Trico' for my '56
    Yes, wiper arms for Corvette were opposing hence there'll be a RH and LH arm. Cars that ran non-opposing sweep patterns used the same arm for both sides.
    Getting real McCoy arms for your car is a tough enough task these days without having to worry about the seller goofing up! But, since the C1 arms were fixed (mid-year and Shark used arms with a cant adjustment to skew the angle of the blade relative to the arm and that adjust screw has to be positioned up), you can 'make' a RH arm into a LH arm...
    Simply clamp the tip in a vice and SLOWLY and gently bend the spring steel 90 degrees to the opposite orientation.
