Factory Traction Bars 1961 - NCRS Discussion Boards
  • Richard P.
    • April 1, 2001
    • 42
    Could you get traction bars from the factory or GM dealer installed in 1961 or other years on Corvettes?
  • Clem Z.
    • January 1, 2006
    • 9427
    my new 62 came with a "traction" bar
    mounted to the top rear axle and to the frame. i tore both loose drag racing. i think they were to prevent axle hop on braking not accelleration
    • Louis Kolb
      Re: Factory Traction Bars 1961
      Yes, as part of the rear suspension design, there was a 'strut rod' from the top of the axle to the frame, on each end, that kept the axle from rotating. This strut rod acted as a traction bar. This was standard equipment.
      • Richard P.
        • April 1, 2001
        • 42
        These look like normal traction bars from the bottom of the spring to the frame.
        • Mike M.
          • May 31, 1974
          • 8385
          sounds like the aftermarket traction bars sold by the likes of Lakewood. mike
          • Patrick T.
            • September 30, 1999
            • 1286
            Here is a pair of very old Lakewood traction bars that were on my '57 when I bought it. PT
            • Mike McKown
              If they mount on the bottom of the spring and are fixed to the frame at the front spring eye, they're probably Traction Master brand bars. That's what a lot of guys used after they ripped the stock ones loose like Clem did.
              The ones Patrick posted a picture of were "slapper bars" and they became common, at least in my area about 1965 or so. I think Lakewood made one of the first designs followed by everybody and their brother.
              • Dennis A.
                • April 30, 1999
                • 1010
                Yes...that's them, I have a set in my oldie storage bin.
                • Rob Edwards
                  Wait- you mean these aren't 'original'? *NM*
                  • Clare Carpenter
                    Re: Wait- you mean these aren't 'original'?
                    Rob, My car ('62) came with the same set up when I bought it back in the 80's. They work like a charm, very nice launch. I noticed you have a slightly bent U-bolt, mine did too, the U-bolts have to be quite long to clear the sway bar mount using the spacers. Once I started on a frame off I inquired to Traction Master in CA about refurbing mine with new front mounts, poly bushings and hardware. They no longer had the drawings so I sent them mine as a reference to work from. You can now buy a set of new Traction Master traction bars for your vintage solid axle. The only diff is the saddle mounts underneath the axle are now welded instead of cast. I decided not to use them for the present since I've never driven the car without them. I'd like to see how it rides and handles without the T-bars. Using them on a '61-62 with factory strut rods, you have a multi link set up on the rear axle and I think quite a bit stiffer ride. If anyone is interested in them contact Chuck at Traction Master.
