Waterpump rebuild - NCRS Discussion Boards
Waterpump rebuild
  • Don Z.
    • August 31, 1998
    • 254
    Waterpump rebuild
    I want to send a waterpump out for rebuilding since I do not have the equipment and probably know how. I searched the archives and found 2 names, Bill Mock & Arthur Gould. I have located Bill in the Driveline. Does anyone have phone number or e-mail for Arthur? Also in Driveline was Goat Hill. Anyone have dealings with Goat Hill? Any suggestions or comments appreciated. Thank You
  • KEN BUTCHER
    Re: Waterpump rebuild
    Hey Don,
    hope this will help you out and you can do it yourself with the pictured instructions. Go to www.corvettemagazine.com/2006/january/waterpump/waterpump.asp
      Arthur Gould - (631) 269-0093.
      • Don Z.
        • August 31, 1998
        • 254
        Thank You John & Ken.
        John, is Arthur in New York?
        Ken Thanks for the info. If I can find a press I may just try my hand at the rebuild myself.
        • Roy B.
          • February 1, 1975
          • 7044
          Also be sure to use the original water pulley or fan or what ever others call it inside the pump so that you don't increase water flow .
          Flow to fast creates heat-- water cant cool in radiator
          • Harry Sadlock
            Re: Water pump rebuild
            Ken, that is a great article. I was looking at STEP 14. I seem to recall that the 63 608 Water pump had the flat back. The article indicates that the flat back was not used in the 60's.
            Does anyone know for sure?
            Harry
              • 43221
              Don-----
              I strongly recommend that you entrust your waterpump to Bill Mock or Arthur Gould for rebuilding. Both of these have long-standing and outstanding reputations for competence and SERVICE. Unfortunately, numerous problems have been reported with Goat Hill.
              • Don Z.
                • August 31, 1998
                • 254
                Thanks to all for the information. I'll contact Bill & Arthur for costs.
                  On the rear plate, the last mention of which style rear plate was used for SB water pumps in NCRS JG text is in the '56-57 book that calls out the flat style plate for both the '911 and '493 pumps. The JG books are silent on what was used from '58-62, but most originals I've pulled off scrap yard cars continued to use the flat plate.
                  The JG books call for BB pumps in the '65-67E era to use the flat plate and I've found original pumps for the era (some NOS service spares still in box) with both styles, but the preponderence having flat plates. This says the flat plate was alive and well (at least at Tonawanda) WELL into the 60's...
                  The stamped plate (reinforced edge) is obviously superior for holding its dimensions, but a freshly die cut flat plate DOES work (obviously--GM used this design for years!)...
                  • Mike B.
                    • November 1, 2004
                    • 389
                    I just used Arthur Gould who turned my pump around in three days. It cost $65. I am happy with the work but after I mounted the pump I realized that the front pulley hub was not pressed back far enough on the shaft. Now my pulleys don't line up. I plan to post a message on this board asking for the correct dimensions so that I can instruct Gould to press the hub in further. To be fair, this was a replacement 609 pump that I found at a swap meet. It had never been mounted on the engine so I don't know if it had the correct distance in the first place. Regardless, I now have to take the blasted thing off again.
                    So, a word to the wise is to carefully measure the distance from the front of the hub to say the flange faces where they meet the engine block and be sure to provide that to Gould or whatever rebuilder you choose so that everything will line back up. There is no room for adjustment after the fact.
                    Mike
                    • Frank C.
                      • January 1, 1986
                      • 277
                      Hi...does anyone recommend any kind of rust prevention for the inside of the pump. TIA Frank
                        The same proceedure...
                        as used to preserve the water jacket of the block and cylinder heads...nothing.
