63 T-10 front bearing Retainer - NCRS Discussion Boards
  • Richard W.
    • November 1, 2005
    • 62
    Can someone supply the part number for the front bearing retainer on a 1963 Borg Warner T-10? The casting number is 591620. Could this also be the part number? Mine is cracked and needs replacing. Thanks
  • Verne Frantz
    Re: 63 T-10 front bearing Retainer
    Rick,
    The one for your application (using the 421 bell) was originally p/n 3790278.
    Verne
    • Richard W.
      • November 1, 2005
      • 62
      Thanks Verne. Any idea is these are available and from whom?
      • Verne Frantz
        Rick,
        Most transmission rebuilders might be able to provide a good used one. I'd suggest Larry Fisher as one to trust.
        Verne
        • Richard W.
          • November 1, 2005
          • 62
          Thanks again. Will try him.
          • Donald L.
            • September 30, 1998
            • 461
            If Larry doesnt have it try Ed Hartnett in Langhorne, Pa. (610) 623 9381
            • Michael H.
              • January 29, 2008
              • 7477
              Verne, Rick,
              Pretty sure the part number you will need is 604932. The original number, 3790278, was only used in production for a short time and replaced with the 604932. I believe the 278 was an aluminum part and the 932 replacement was iron. The 932 was available in service until the mid 80's.
              • Verne Frantz
                Yes Michael, the new number was put in service sometime between Jan.'63 and Oct.'63. A very brief run for the original aluminum retainer...
                Verne
