Mystery part_ steering column - NCRS Discussion Boards
  • Steve D.
    • February 1, 2002
    • 990
    63 convertible__
    Does anyone recognize this small red plug with a hole in the center? It was among my steering column parts, in a bag by itself, neatly labeled "you found this in the AIM once, find it again". So far I haven't found it again.
    Steve
  • Timothy B.
    • April 30, 1983
    • 5186
    Re: Mystery part_ steering column
    Steve,
    I believe this plastic bushing slips on a (tit) on the turn signal ring which is inside the control assembly and is also indexed to a (W) shaped wire piece that holds the left or right blinker on until it is cancelled by the cancelling cam. Section 12 in the AIM shows the assembly but I did not see this part.
    • James W.
      • December 1, 1990
      • 2655
      It may be the insulator for the horn contact button so that it will not make metal to metal contact with the steering wheel hub?
      James West
      • Bob R.
        • June 30, 2002
        • 1595
        Tim's post was correct this part rides back and forth on the spring wire and is controlled by the canceling cam. It should have a little bit of lithium grease on it. If you go to the Long Island Corvette web site and check out Section 18 they show a blow up of the column. Part # 56 directional roller is the part you are talking about. It slips over part # 54 turn signal metal ring.
        • Steve D.
          • February 1, 2002
          • 990
          That's it. Thanks.
          Steve
