1960 C1 tag - NCRS Discussion Boards
1960 C1 tag
  • Don 42616
    1960 C1 tag
    On a 60 how is the vin tag attached to the L door jamb (rivets)?. also is there a motor deck stamp ? Castinging date/location? I am not familiar with C1s.... Thanks, Don
  • Mike M.
    • May 31, 1974
    • 8385
    Re: 1960 C1 tag
    vin plate secured to door jamb with pan head phillips screws. pad stamped. casting # and date cast into block. ya need to buy the 58-60 judging manual and noland adams vol 1 book from the ncrs on-line bookstore. assembly manual also helpful. mike
    • Mike E.
      • February 28, 1975
      • 5138
      Re: 1960 C1 tag
      Many 60's weren't attached to the door jamb as I recall--but were attached to the steering column as were 61-62's. I'm not sure of the cutoff on that.
      • Jim D.
        • 2884
        Re: 1960 C1 tag
        About car #1500 it was moved to the steering column.
        • Don Izzo
          Re: 1960 C1 tag
          My 60 has the vin tag welded on the steering column inside the engine compartment. Car was built in July of 1960. Hope this helps
