Test gauge deterioration - NCRS Discussion Boards
  • Rick C.
    • March 1, 1986
    • 183
    Will my compression gauge and vacuum gauge go out of calibration over time? Does the diaphragm or whatever is inside get stiff with age and cause lower than actual readings? If so, how long can one expect to get accurate readings before having to replace the gauge? Thank you.
