C2 p/brake slider - NCRS Discussion Boards
C2 p/brake slider
  • Steve Shanks
    C2 p/brake slider
    After the usual push,shove,twist and almost standing on the head to get the p/brake console out I looked at the replacement slider and it had a pre-cut slot..do I presume that that is for the Dummy on this end..so I don' have to take the console out.I can take one or two Ha Has, please no more than two..Thanks ,SteveS.
    • 43221
    Re: C2 p/brake slider
    Steve------
    The slit in the 67-82 parking brake lever seal ("slider"), if that's what you're talking about, is necessary for the seal to be installed around the lever. It has nothing, at all, to do with installing the seal without removing the parking brake console. There's no way that I know of to install this part unless the parking brake console is first removed.
    • Steve Shanks
      Thanks Joe, guess it was wishful thinking on my part. I stopped the removal when I couldn't get to the two screws about 1/3 back from the buckles. Time to go back to the job. Any more than the 4 screws (or surprises) that I should know about ? ta steve
      • David M.
        • September 30, 2004
        • 522
        (Message Deleted by Poster)
