Re: 66 Main Wiring Harness - NCRS Discussion Boards
  • Tom B.
    • February 1, 1994
    • 779
    Ed,
    In case you're referring to the 66 Main Dash Wiring Harness, then the thing I used to replace mine at the time was the 66 AIM. It was pretty clear-cut and straight forward. Also, you're looking at a job that isn't high on the degree of difficulty, but is high on the level of disassembly. If you have anything else that you might want to replace, work on, or restore that is dash or interior firewall related, then now would be the time to do it. Also, take your time, have plenty of patience. That will help the most when doing this job right and not spend a lot of time looking for any shortcuts. Hope this helps. TBarr #24014
