1963 steering problem - NCRS Discussion Boards
  • Ray C.
    • June 30, 2001
    • 1132
    When turning the steering wheel full right or left the rear inside edge of the tire will rub on the frame. Where did I go wrong?
    Thanks for any help!
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
    • 15676
    Re: 1963 steering problem
    What is your wheel size, offset, and tire size.
    Unless you're running the OE wheels and 6.70-15s a little frame rub at full lock is not unusual and does not represent a safety issue since you only engage full lock at parking lot speeds.
    • Ray C.
      • June 30, 2001
      • 1132
      Thanks Duke
      I have installed the tires P205 75 R15 that were on the car when I purchased it. The only thing I have changed is to remove the Western reproduction knock-offs and install original 63 wheels with the hub caps.
      Again, Thanks
      Ray
      Ray Carney
