57 Exhaust Manifold - NCRS Discussion Boards
57 Exhaust Manifold
  • Michael K.
    • August 31, 2004
    • 170
    57 Exhaust Manifold
    Is it recommended that I install the french locks on my exhaust manifold bolts? I presently do not have any type of lock washers. Also, I noticed that spacers are recommended fot the outer attaching positions. I will be using gaskets so I am not sure that they are needed.
  • Mark S.
    • July 31, 1983
    • 660
    Re: 57 Exhaust Manifold
    Spacers may not be needed; but they were included on the inital installation, along with french locks. This may be a minor deduct, if you are having the vehicle judged; and another minor deduct for the addition of gaskets. Enjoy the vehicle the way you want!
    • Michael H.
      • January 29, 2008
      • 7477
      Mike,
      It is HIGHLY recommended that you use no gaskets between the exhaust manifold and cyl head. No gaskets are needed but, more importantly, they can easily cause cracking of the manifolds. The first two years of the small block engine used gaskets but the cracking problem led engineering to eliminate them for the 57 and later models. If the machined surfaces on the manifold and cyl head are decent, there will be no leakage.
      The french locks and washers are a good idea for the end locations as the bolts may loosen without these items. The wide range of temp difference between the cyl head and manifold seems to have an effect on the end location bolt torque.
      • Mike E.
        • February 28, 1975
        • 5138
        Spacers weren't there for looks, obviously--my understanding is that they were there so that the exhaust manifold bolts intersected the head the appropriate depth. Why not just the correct length bolt? No idea.
        • Robert L.
          • April 30, 1979
          • 97
          I think only 4 spacers were used. Can't remember if they were for the inside or outside bolts. All the bolts were the same length. Not using the spacers results in the bolt interferring with the piston. Not good.
          Hope this helps.
          MCMLVII
