C-1 Front Bumpers - NCRS Discussion Boards
C-1 Front Bumpers
  • David D.
    • 330
    C-1 Front Bumpers
    Any difference between 58-60 and 61-62 front bumpers? I know the part numbers are different. TIA. Dave
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C-1 Front Bumpers
    58-60 same---------61-62 same but dont interchange
    • David D.
      • 330
      Thanks Roy. Is there any way to tell the difference, between them? The ones I have look to be new reproductions. The only thing I see stamped on them, is a W on one of the mounting brackets, on each bumper. Also, any demand for 53-55 rear bumper (center, banana shaped piece, with four 3/8 inch studs for mounting). It looks to be a rechromed original, no markings or stamps anywhere on it. Dave
      • Richard T.
        • February 1, 1979
        • 858
        The only difference between 58/60 and 61/62 front bumpers is the location of the grille bar mounting studs. If you use 58/60 bumpers on your 61/62 the grille bar will sit too far back and leave an opening at each edge. Very noticable when installed. Rich #2276
        • David D.
          • 330
          Re: Thanks, Rich. *NM*
