1963 body mount - NCRS Discussion Boards
1963 body mount
  • Ray C.
    • June 30, 2001
    • 1132
    1963 body mount
    How much movement of the body front to back is there with the body mounts? I have the body back on a new frame, but it needs to move toward the rear of the frame. The bumper brackets are placing pressure on the rear body panel and I would like to gain more adjustment with the clutch pedal rod from the pedals.
    As always thanks for any help!!
    Ray
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • mike cobine
    Re: 1963 body mount
    There is some room, if I remember right. Mine is bolted down or I'd check a hole. Just loosen the body bolts and see how far you can slide it back. Maybe 1/4 inch?
    • Ray C.
      • June 30, 2001
      • 1132
      Re: 1963 body mount
      Thanks Mike!
      I loosened the body mounts and moved the body back about 1/8". The frame is a new frame and I believe that the mounting holes on the frame are off slightly. I filled the elliptical hole another 1/8" and the brackets now fit fine.
      Thanks for the help!
      Ray
      Ray Carney
        Re: 1963 body mount
        Ray -
        Original factory frame hole tolerances were +/- 3/8" from gage dimensions; pretty generous.
