GM part # meaning please - NCRS Discussion Boards
  • Keith B.
    • August 12, 2007
    • 220
    Can anyone tell me what GM part #3877215 refers to please. Is it for a 65-67
    side exhaust pipes???? I knew I should have bought a parts # book sometime ago........Thank-you...cheers/
  • Wayne M.
    • March 1, 1980
    • 6414
    LH '66-67 327 side exhaust for 2 inch manifolds
    1965 side exhaust small blocks had the 2.5 inch exh. manif. and used 3872971-2 (LH-RH) muffler/pipe.
    • Keith B.
      • August 12, 2007
      • 220
      Re: LH '66-67 327 side exhaust for 2 inch manifold
      Thanks Wayne: This number I noted is different than the SB # you listed.
      Part # 3877215 is the one I'm curious about, I have a 66 BB 427 car and want to know if this part # will fit???
        3877215 is a left-hand 2"-outlet small-block sidepipe; won't work for your car without major surgery and inlet pipe fabrication.
        • Wayne M.
          • March 1, 1980
          • 6414
          You'll need 3845735-6 for L-R '65-67 BB's *NM*
