68/69 wiper door question. - NCRS Discussion Boards
  • Terry F.
    • September 30, 1992
    • 2061
    Hi, I was wondering if the 68 people and early 69 people could let me know if they have a screw located on each end of their wiper door used to hold the stainless trim piece down.
    The reason I ask is this. I want to find out approximately where in the 68 production they started to use the screw to assist in holding the trim piece down. I would also like to know if this was a screw or a push-in rivet? Assembly manual says screw but the one or two I recall seeing reminded me of a push in rivet.
    Any information or observations on this would be appreciated.
    Thanks, Terry
  • Pat K.
    • November 1, 2003
    • 351
    Re: 68/69 wiper door question.
    Terry,
    I have a Feb '69 and it has a rivet.
    Pat
    • Terry F.
      • 2061
      Thanks! Terry *NM*
      • Dick W.
        • 10483
        Terry, the screw, rivet, was a drive rivet. It has a dome head and a twisted or screw shank.
        Dick Whittington
        • Don Izzo
          Dick would you know if this screw/rivet is available at any of the usual sources? My June 68 was missing the moulding when I got the car. I have since replaced the moulding but never installed the screws although the holes are present in the ends of the door.
          Don
          • Terry F.
            • 2061
            Thanks, I thought it was something like that. I have a friend that is restoring a June 68 corvette. Trying to gather information about when the rivet showed up. The tech bulletin 68-T-45 dated April 24 describes a clip that was added to the ends of trim piece to help prevent rattles. Those clips are different than the 4 main larger clips that attached the stainless trim. The assembly manual that I have does not show the clip but does shows the press in rivet. In the changes it says the rivet was added 2/9/68. I find that interesting because my May built car does not have the rivet and I am confident it is the original wiper door. So, it must mean that there is or can be a considerable lag to when something was added to the assembly manual and when it actually hit the assembly line. I have contacted several 68 owners and I am hoping to narrow down the time frame in which the rivet showed up. If anyone needs a picture of where to look for the rivet, just email me. Terry
              • 15601
              "So, it must mean that there is or can be a considerable lag to when something was added to the assembly manual and when it actually hit the assembly line."
              You have it right -- but sometimes it can work the other way -- the changes are made to the cars before the drawings hit the AIM. The only way to know for sure, especially for a 1968, is to survey other cars. Just like you are doing.
              • Terry F.
                • 2061
                Thanks for the feedback! Terry
                • Larry Kelly
                  Terry,
                  I took the rivit out of the door that I sent you the picture of. The head is on bad condition but I estimate it was 7/32 dia. The body of the rivit is about .110 with a high spiral and is .250 long.
                  • Terry F.
                    • 2061
                    Thanks! Terry. *NM*
