Mechanic recommendation in Oakville/Toronto area? - NCRS Discussion Boards
  • Mark K.
    • July 31, 1995
    • 123
    I recently brought a '67 coupe into Canada and need to get it certified (safety checked) before registering it. Can anyone recommend a good mechanic in the GTA area that knows older Corvettes? Thanks in advance, Mark
    Mark
    '70 Cortez Silver LS5 Coupe
  • Mike M.
    • September 30, 1999
    • 710
    Re: Mechanic recommendation in Oakville/Toronto ar
    Mark go to NCRS ont site and send a email to Scott Sinclair he is from your area and will know where to take it. Just click on his name on the right side.
    Mike
    • Paul L.
      • November 1, 2002
      • 1414
      Here is a lead for you. But quite frankly the safety check can be done by any certified inspection station including GM dealers. If you have lights, a sound exhaust system, brakes, good tires, solid steering and suspension, etc. the car will pass. These are simple tests that can be done by a licensed technician. You do not need a Corvette specialist.
      • R N.
        • May 31, 2002
        • 640
        ES Auto
        Ed Szram
        905-853-3777 based in Newmarket.
        • Mark K.
          • July 31, 1995
          • 123
          Thanks guys, I appreciate the responses. Stingray is only about 15 minutes from my place, so that may be my best bet! Mark
          Mark
          • Susan G.
            • May 31, 2005
            • 136
            Hi, I live in Oakville myself (close to Longos) and have a 58 just about finished for the second time around. We should get together and compare notes. I have used alot of mechanics and could suggest some depending on what you need done. Hope to hear from you. Contact me a David.Gilbey@aexp.com.
            Regards Susan
