C-3 bogging & hesitating - NCRS Discussion Boards
  • Dave Jarosz
    My `76 has a fuel delivery issue that comes and goes. It drove great for the past month but last week it started to bog, or starve for fuel when I booted the gas pedal a bit aggresively. Could it be a carb rebuild, (original carb 58,000mi. not yet rebuilt) or the fuel sending unit. Or something else....Please help
  • lyndon sharpton
    Re: C-3 bogging & hesitating
    change your filter on that Q-jet!
    • Michael W.
      • April 1, 1997
      • 4290
      If it only bogs only when you 'floor' it, possibly the secondary air door return spring might be a little too loose.
      Have a look in the shop manual or any Qjet book on how to find and adjust it.
      • Clem Z.
        • January 1, 2006
        • 9427
        also the pickup tube for the secondary
        pull over enrichment have fallen out of their place in the top carb body. if there are 2 horizonal holes in the carb top just above the front edge of the secondary air valve your carb has this feature.
        • lyndon sharpton
          well did you get that bog out? let us know.
          • Jim Tipton
            Just a thought but look in your gas tank with a flashlight and see if there is an obvious line where the water in youg gas tank has seperated from the gasoline.
