ZR1 valet switch - NCRS Discussion Boards
ZR1 valet switch
  • Mike M.
    • May 31, 1974
    • 8396
    ZR1 valet switch
    GM has discontinued the valet switch that pulls in the secondary injectors. need one for a 95 ZR1. anybody got a source? thanks, mike
    • 43234
    Re: ZR1 valet switch
    Mike-----
    Yes, the GM #12514730 switch is, indeed, discontinued. This was a very expensive switch----over $200, GM list, when it was discontinued. The only suggestion I could make on this one would be to try a source like "partsladi" which sells a lot of lae model GM parts on eBay. You can e-mail them at lyddu@aol.com
    • Mike M.
      • May 31, 1974
      • 8396
      thanks joe. will try them. mike
        • 11648
        Mike,
        Is a 95 different than a 90 or 91?
        I know someone taking one apart, and he may still have that switch in the car.
        Patrick
          • 43234
          Patrick-----
          1990 used a switch unique to that year. 1991-95 were the same. So, if the car you are referring to is a 1990, the switch won't work for Mike; if it's a 1991, it will.
            • 11648
            Thanks Joe. I'll check.
            I "think" it's a 91 if Mike is interested.
            Patrick
            • Mike M.
              • May 31, 1974
              • 8396
              pat would appreciate you looking into the switch. joe's correct, the 90 switch is unique to 90 whereas the rest of ZR1's used the switch i need. thanks, mike
                • 11648
                Mike,
                I've sent him an e-mail asking if it's available. I'll keep you posted.
                Patrick
                • Mike M.
                  • May 31, 1974
                  • 8396
                  thanks pat. owe ya one. mike
