Tire Recommendations Please - NCRS Discussion Boards
  • Kevin Cavanaugh
    I am in the market to put a new set of tires on my 1969 big block and I am looking for opinions. This is not a show car(although it did get 3 stars in Bowtie judging) and I only drive it occasionally. How about opinions on Coker reproduction tires(do they make a repro of the F70-15 Goodyear Speedway blackwall?)Any comments on the Diamondback Classics? Also what metric size will work well that is the equivalent of the F70-15? I'd like to have the performance of a radial tire, but I'd like them to look as correct as possible. Opinions???
    • 15674
    Re: Tire Recommendations Please
    Look at the Spring and Summer 2003 issues of The Corvette Restorer if you want an indepth analysis and a discusssion and test results of the best available choices.
    • mike cobine
      I always thought a Corvette should outhandle other cars. If you put F70-15 tires on it, your Ford Explorer will outhandle it.
      In '73, then began using the GR70-15 radial and it looked good in the opening. Today, you would be a 225/70-15 for that size. In '78, they added the 255/60-15. However, that will rub your front fender lips as they trimmed them on the '78 and up with the 255/60.
      A 245/60-15 will fit nicely, if you can find that size. A 235/60-15 is a bit too small, but will handle better than the 225/70-15.
      • Thomas C.
        • August 31, 2000
        • 133
        I have repro Goodyear speedways on my 69. They get terrible flat spots and follow grooves in the road horribly. I also have Firestone wide oval repros on my 72 and they seem to be much better tires to drive on although still not close to the performance of the radials.
