68 vs 69 frame questions.... - NCRS Discussion Boards
  • Terry F.
    • September 30, 1992
    • 2061
    Any easy way to physically tell a 68 frame from a 69 fram?
    Also, I heard the front bumber corner braces are unique to 68...is that true?
    Thanks, Terry
  • Larry Kelly
    Re: 68 vs 69 frame questions....
    A 68 frame will not have gussets welded in the kickup area (in front of the rear wheels). I believe this was changed during the 68 production or 69. The 68 extensions on the front of the frame rails are different as are the corner braces. I have used later corner braces by slotting one of the holes. 68 extensions and braces are hard to find.
    • Wayne W.
      • April 30, 1982
      • 3605
      Radiator support mounts like a midyear with one bolt up through the bottom into the support bracket.
      • mike cobine
        The rear frame bracing was added in the '68 year, but I'm not sure when. It was at least by June.
        • Terry F.
          • 2061
          Thanks everyone! Info is for a friend of mine. T *NM*
          • Chuck R.
            • April 30, 1999
            • 1434
            Re: F.Y.I.
            My late production 68 frame DID have the kickup bracing.
            My early production 68 donor frame did NOT
            Chuck #32205
            • Terry F.
              • 2061
              Re: F.Y.I.
              That kick up bracing thing started before May of 68 because my car has it also. I suspect it started fairly early. You can buy that piece if you are needing it. Terry
              • mike cobine
                Re: F.Y.I.
                That brace is pretty tough. You can proably find a donor off some rused out frame relatively easy.
                • Terry F.
                  • 2061
                  Re: F.Y.I.
                  I think they are being reproduced. I forget which catalog I saw it in but I am fairly sure they are out there. Terry
                  • Chuck R.
                    • April 30, 1999
                    • 1434
                    Re: Yup
                    I picked up two repro braces and stitched them on.
                    It ran me $87.50 for the pair including shipping.
                    Chuck
                    • Terry F.
                      • 2061
                      Re: Yup
                      Way to go. I think they are a good idea when it comes to supporting the frame in that area. The only thing I don't like about them is that they make it tougher to get the trailing arm bolts out.
