'71 Key Warning Buzzer - NCRS Discussion Boards
  • Dennis M.
    • April 1, 2006
    • 22
    Where is the key warning buzzer located on a '71?
  • Jim T.
    • March 1, 1993
    • 5351
    Re: '71 Key Warning Buzzer
    Look for it mounted on the fenderwell in front of and to the left of the brake master cylinder.
      • 15606
      It is inside the horn relay, mounted right where Jim said. Check to be sure the connector with the single green wire is plugged in. That is the signal from the reed switch in the steering column.
        The green wire is +12V to the horn; the wire from the reed switch in the steering column is a 20-ga. pink/dark blue/black.
