53-55 Rear Parking Brake Cables - NCRS Discussion Boards
  • Kent K.
    • December 1, 1982
    • 1139
    Out of curiousity, are the rear parking brake cables for 53-55 the same as for 56-62? If not, what are the differences? Does anyone know if the 53-55 rear parking brake cables are being reproduced and which vendor might carry them? If they are not being reproduced, are they available used?
    Thanks, Kent #6201
    Kent
    NCM Founder - Member #718
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 53-55 Rear Parking Brake Cables
    No! they will not exchange the 53 to 55 are totally different , and no one repro's them , now and then you see them on e-bay
    The difference is how they connect to the rear drums and frame.
    • Kent K.
      • December 1, 1982
      • 1139
      Thanks Roy. I was asking for another NCRS member and hope he reads this. Do you know if they can be made from some other cables?
      Kent #6201
      Kent
      • Roy B.
        • February 1, 1975
        • 7044
        I think starting from 1948 to 54 Chevy they would work at the rear drums( same thing) , but then the front area that bolts to the frame is different and would need you to make a support for it. Then you would need to pull the cable out from the drum area end shorten the cable and re-swage a ball back on.
        I think that was how a friend did it years ago.That's the closest cable I know that can be modified
