67 Manual transmission info - NCRS Discussion Boards
  • Ralph Murdaugh
    What are the identification numbers to the manual transmission to the m20, m21, and the m22. Thank You for your help.
  • William C.
    • May 31, 1975
    • 6037
    Re: 67 Manual transmission info
    There are no numbers on the trans of a '67 that will ID an M-20 from an M-21, an M-22 would have a drain plug in the lower Boss of the case, that assumes the trans is an original trans with the 010 case. Later cases all had the drain. If the trans is out of the car, an M-20 will have two grooves on the input shaft in the splined area.
    Bill Clupper #618
    • Joel A.
      • September 30, 1997
      • 205
      Unless the inpoot shaft has been replaced down the line, somewhere. Not all replacement shafts will have any ID grooves.
      Joel Adams
      1974 Coupe
      1985 Coupe
      "I know the voices aren't real...but sometimes they have some really kewl ideas...."
