C2 66 Big Block K19 AIR Carburetor - NCRS Discussion Boards
  • Mark P.
    • July 31, 2003
    • 407
    I need to replace my non-original carburetor on my 390 hp car but don't have the original K19 system on the car. THe question is, if I can find the correct carb, can I use it without the rest of the AIR system or until I get the rest of the components in place? From what I understand (I haven't seen one yet)it connects to the AIR system, but would I have to cap that line somehow?
    Any advice would be greatly appreciated!
    Mark Pugmire
    54 Pennant Blue
    56 Cascade Green Dual Quad
    56 Arctic Blue Dual Quad
    66 Nassau Blue 427 L36 Convertible
    67 Marlboro Maroon L79 Coupe
  • Mike M.
    • May 31, 1974
    • 8389
    Re: C2 66 Big Block K19 AIR Carburetor
    shouldn't be a problem running the correct Holley without the K-19 items. good lcuk finding the pieces. mike
      • 15678
      The AIR carb has ported vacuum advance. I recommend you convert to full time vacuum advance by using a full time vacuum source, like the choke vacuum break, for the vacuum advance signal.
      You can probably also convert to full time my modifying the carb internally.
      • Mark G.
        • March 1, 2001
        • 227
        • Mark P.
          • July 31, 2003
          • 407
          I would really appreciate the pictures if you could send them. Since I am unfamiliar with this unit, I need as much info as possible to be able to see what it is I need to do. Let me know on the pictures. E-mail address is Mark.Pugmire@HCAHealthcare.com. Also, any advice on locating a correct carburetor would be great.
          Thanks much!
          Mark
          Mark Pugmire
          54 Pennant Blue
