60 Wiper arm - NCRS Discussion Boards
60 Wiper arm
  • Larry P.
    • June 30, 1999
    • 481
    60 Wiper arm
    The knurled insert in the arm is worn and pops off. Is there a fix? If not, what's a good source for replacement?
    LP
    Re: 60 Wiper arm
    Drill out the rivet that holds the drive hub to the arm AFTER releasing the tension spring. Replace the drive hub with a fresh one from a donor arm.
    Chevy and other passenger cars & trucks of the era used similar drive hubs on their wiper arms but with different length/different geometry arms. This is how those in the wiper arm 'restoration' business go about fixing original arms that have 'chew' marks on the drive hub and/or bad chrome over the drive hub's pot metal casting.
    Some of the catalog houses sell replacement SS rivets so you can do the job yourself. You'll have to shop for a source...
    • Larry P.
      • June 30, 1999
      • 481
      Thanks Jack *NM*
