$4001 for an air filter!..check out the real thing *NM* - NCRS Discussion Boards
  • Joseph T.
    • April 30, 1976
    • 2074
  • Mike M.
    • May 31, 1974
    • 8385
    Re: $4001 for an air filter!..check out the real t
    filter in picture appears to have the service replacement Black rubber ends. mike
    • Joseph T.
      • April 30, 1976
      • 2074
      Mike..I think what you see is effected by scanning the picture. It is a blue A56C blue in the original picture.
      I think what appears black in the scan of the picture is the edge of the lid!
      Lucky it is this good for an old polaroid.
      Pretty rare stuff.
      Joe
      • Joseph T.
        • April 30, 1976
        • 2074
        Mike..have now identified 3 convertible top airbox cars!
        Joe
        • John D.
          • December 1, 1979
          • 5507
          Joe, According to Noland Adam's book air box cars used an ac element part #1553182. Non-air box used the blue AC 56-C 1553251.(except for the early louvred ac's). Don't know the AC number for the air box car element but we have always thought it was a little larger. Ken Kaiser has this info if you need it. John
          • Joseph T.
            • April 30, 1976
            • 2074
            John..I went back and checked Nolands..comments and the 57 AIM...and you are right..about the #1553182 being designated as the element for the air box..
            Now I am curious what the differance is between #1553182 and #1553251. The picture I posted is the only one I have that shows the filter in a real car before restoration and it appears to be at minimum an AC56.
            I will check with Ken to see if he knows or has the blueprints. I wonder if a member has an old AC Delco filter book that can identify the AC# for element 1553182.
            I figure if historians can determine what the Egyptians did 5000 years ago..we should be able to find out what GM and AC Delco did 50 years ago.
            Many thanks,
            Joe
            • Frank C.
              • January 1, 1986
              • 277
              Re: element part #1553182
              Hi Joe....I have an AC Filter interchange book, but is dated as April '79 and doubt that it goes back far enough. I'll look anyway when I get a chance and let you know if I come up with anything....Regards Frank
              • Joseph T.
                • April 30, 1976
                • 2074
                I looked at the remnants of what appears to be the original air box air filter element from a very complete unrestored air box car today.
                I need to send the dimensions of my original A56C to the owner for him to compare the specs.
                Joe
                • Frank C.
                  • January 1, 1986
                  • 277
                  Joe...I looked thru the AC filter interchange book I have and only confirmed what you already knew. Looking thru my March '65 Chevrolet parts book, and I found in addition to the element #1553251 (A56C) that is was used with air cleaner #1553181. But you probably already knew that. I scanned a little bit but did not see #1553182 (probably removed before the parts book was printed???). As I am not a C1 guy, which one is the air box #? Wish I could be more help. Regards Frank
