C-1 Trunk Liner - NCRS Discussion Boards
C-1 Trunk Liner
  • Dwight Bedsole
    C-1 Trunk Liner
    The Judging Guide says that all '58 thru '60 had a bulge in the trunk division trim panel which was compatible with installation of power top equipment, even those with non-power top. Corvette Central sells two types of molded liners, (1) w/Power Top Molded and a (2) w/o Power top Molded . My car does not have a power top, which liner is correct ?
    Dwight
  • Mike E.
    • February 28, 1975
    • 5138
    Re: C-1 Trunk Liner
    Which has less to gain from your purchase of a liner---Central or NCRS?
    Go with the advice of the one who has nothing to gain.
    • Dwight Bedsole
      Re: C-1 Trunk Liner
      Maybe I should re-phrase my question. NCRS says the proper liner is a molded liner. CC sells two different types of molded liners. My question was aimed at trying to determine which molded liner is acceptable to NCRS.
      Dwight
      • Roy B.
        • February 1, 1975
        • 7044
        Re: C-1 Trunk Liner
        Correct!!
        • Dennis A.
          • April 30, 1999
          • 1010
          Re: C-1 Trunk Liner
          Dwight....
          On non-power top cars, the panel is flat. Original panels were marked with an "FP" logo. Panels are held in place with four clips marked with a "T" within a diamond.
          • Roy B.
            • February 1, 1975
            • 7044
            Re: C-1 Trunk Liner
            I disagree 53 to 55 flat,56 to 60 bulge weather PT or not having a "W" logo, 61 to 62 flat if no PT . You see mostly flat because for many years they only repro-ed flat ones.But! that's what I've seen over the last 35 years in original Corvettes. My 2cents
            • Dennis A.
              • April 30, 1999
              • 1010
              Re: C-1 Trunk Liner
              Roy...
              I agree, Forgot about the years prior to 61.
