C1 Heater Seal to Fire Wall - NCRS Discussion Boards
  • Jimmy J.
    • May 31, 1988
    • 304
    What is the correct sealing compound and color to seal the heater to the firewall? Thanks, Jimmy
    Re: C1 Heater Seal to Fire Wall
    Jimmy -
    3M Strip-Caulk ("dum-dum") works fine.
    • Jimmy J.
      • May 31, 1988
      • 304
      John, is it black or gray? Thanks for your reply. Jimmy
      • Mike E.
        • February 28, 1975
        • 5139
        I might be reading your question wrong, but my experience is that the large black rubber gasket that seals the air intake piece (snout) to the rest of the heater is also the seal to the firewall. That's the case at least from 56 through 62.That is a black/charcoal color.
        • Mike M.
          • May 31, 1974
          • 8389
          mike: perhaps john h is thinking of the c-2's which did have a tar-like substance that sealed the duct to the firewall. mike
          • Jerry C.
            • November 1, 1995
            • 741
            I have always got a deduct if black dum dum was not around the fresh air box on the firewall and around the heater hose where it goes thru the firewall.
            • Dennis A.
              • April 30, 1999
              • 1010
              CC part number 451015 for the C1 Heater Gasket Set...
                Mike -
                I was trying to recall my '57 (which I did ten years ago); I think it used a formed gasket between the air inlet housing and the firewall that was made from a dum-dum type material, which one could make from strip-caulk material. Just looked in the Doc's catalog, and sure enough, he has that formed "putty" gasket. CRS after ten years
