C2 steering box lubricant - NCRS Discussion Boards
  • Garry E.
    • September 30, 2002
    • 240
    My '64 has a steering box that has developed a slow, steady leak.... I'm going to have it rebuilt, but for the moment I need to refill the lubricant. What type of lube should be used....?
    Garry
    • 43211
    Re: C2 steering box lubricant
    Garry-----
    GM #12377985.
    • Garry E.
      • 240
      Is this a heavy-weight oil.....?
        It's chassis grease - same stuff you use on the grease fittings.
          • 15661
          If you're going to have it rebuilt, just use any EP chassis grease.
          Someone may have put gear oil in it, which is more prone to leaking.
          For the rebuild I recommend a full synthetic EP chassis grease. The steering gear absorbs a lot of radiant head from the exhaust system and a full synthetic grease should have better long term oxidation stability.
            • 43211
            Garry-----
            As John describes, it's a chassis grease. Some folks, including some GM part countermen, think that Corvettes used the same lubricant that is used for most other manual steering boxes. That is a heavy-weight oil type lubricant. However, Corvettes are an exception. ALL 1963-82 Corvettes used a grease the viscosity of chassis lube. Originally, this was GM #1052084. That product was discontinued about 10 years ago and replaced by the product I mentioned.
            • Chas Henderson #28127
              How much do you use?
              Chasman
                • 43211
                Chasman----
                It takes about one 14 oz tube for a complete fill.
