'66 PW Brake question - NCRS Discussion Boards
  • Phil B.
    • Today
    I'm installing PW Brakes on My '66 Coupe. Got some great advice regarding studs, and upper bracket holes. On the pedal assembly is two pin locations. Which should I use for power brakes? Thanks.
    Re: '66 PW Brake question
    Eric -
    As shown in the J50 section in the Assembly Manual, you use the lower hole for the booster pushrod clevis, and the upper hole for the striker bracket for the brake light switch.
