67 BB TI Coil 1115263 - NCRS Discussion Boards
  • Richard S.
    • November 1, 1994
    • 809
    I'm going to buy a new TI Coil for my 67 427/435 car. Long Island has them for $220. and Corvette Pacifica is offering new correct for $121. on E-bay....
    Can anyone advise if there is a difference I should know about.....thanks.
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: 67 BB TI Coil 1115263
    the turns ratio should be different between a TI coil and a points coil and their ad says it will work for both. i would get them to supply the resistance reading of the windings so you could compare them to the specs in the corvette shop manual
    • Richard S.
      • November 1, 1994
      • 809
      Clem,
      Nice to hear from you....hope you are doing well. I thought a TI coil could be used for both applications but a standard coil would not work for TI applications....am I wrong....thanks.
      • William C.
        • May 31, 1975
        • 6037
        The coil shown in the pacifica ad does not show the embossed part number, nor can I make out the printing on the top of the coil, may or may no be accurate based on the picture, in addition to Clem's comments.
        Bill Clupper #618
        • Warren F.
          • December 1, 1987
          • 1516
          Rick,
          I personally looked at the '263' coil that Goat Hill Classics sell. It looks correct and is supposed to be internally built correct as well. I know alot of members here are not fond of this vendor, I personally only buy when he is at the different shows. I will probably see him at Turlock May 7th here in California, could pick one up for you if you'd like. I think he is at $240, however at the show I think he sells for $210.
          Both my '71 LS-6 cars use that coil as well.
          • Joel Falk
            I have one of these coils from Pacifica and the resistance is .9 Ohms, which is higher than TI Speicalties suggests (.41 - .51), but lower than that of a points coil (1.26 - 1.46). There is a strong possibility my ohmmeter is a POS.
            I have not yet installed it so I can't comment on it's performance
            • Rob A.
              • December 1, 1991
              • 2126
              Rick,
              I installed a #263 from Long Island on my '67 400HP and it operated fine.
