1967 Exhaust tips - NCRS Discussion Boards
1967 Exhaust tips
  • Chuck M.
    • February 1, 2002
    • 335
    1967 Exhaust tips
    Hi,
    Wanted to know what the correct part number is for a correct pair of 1967 exhaust tips. Thanks.
    Chuck
    • 43239
    Re: 1967 Exhaust tips
    Chuck------
    GM #3819573. However, this part was discontinued some time ago.
    • Chuck M.
      • February 1, 2002
      • 335
      Joe,
      Thanks! Are the part numbers stamped on the outside?
      Chuck
      • larry linkous
        Can you buy repo's anywhere for side exhaust?? *NM*
        • William C.
          • May 31, 1975
          • 6037
          Replacements (over the counter circa early 70's) carried the numbers on the outside, originals did not. Also look at the thickness of the metal, and the position of the weld seam (should be on the bottom) the originals are stainless, but will show an attraction to a magnet.
          Bill Clupper #618
          • John S.
            • July 31, 1990
            • 292
            Re: 1967 Exhaust tips are u saying
            Bill; I was under the impression that all orginal tips had the part numbers stamped on them. I have two NOS ones that do not have any part number. I wandered why they didn't. Did the thickness of the metal differ in orginals to over the counter?
            • Harry Sadlock
              As far as I know, there were no part numbers on the factory installed originals and the metal is very thin.
              Harry
              • William C.
                • May 31, 1975
                • 6037
                No part numbers, thin metal, weld on the bottom on original items. I believe most of the judging guides have caught up with this by now. In '73 I bought a new set from Chevy for my '65, they had part numbers, and I was Mad as heck! I had paid good $$$ for a part that was not the same as the one I took off the car (and kept) Later variations had the weld seam running just about anywhere, including on the top. "low bidder!" on service parts.
                Bill Clupper #618
                • Stephen L.
                  • May 31, 1984
                  • 3158
                  Re: Can you buy repo's anywhere for side exhaust??
                  Chrome tips for side exhausts are available from many Corvette vendors. Check the catalogs...Volunteer, Paragon.... etc.
                  • larry linkous
                    Thanks Steve !!!!!!!!!! *NM*
