1967 heater hose with A/C and smog question - NCRS Discussion Boards
  • larry linkous
    Does the orginal heater hose for 1967 Corvette with 427 and A/C have any writing or letters on it?? I know it was ribbed but when I went to order repo's they stated they did not have the lettered one's just the ribbed. If so where is a good source. Also need a bracket for a big block 1969 A.I.R, pump faily quickly. Any ideas where I can get one. Thanks
    Re: 1967 heater hose with A/C and smog question
    Larry -
    Do you have the '67 JG? It describes in detail what both the 5/8" and 3/4" heater hoses are expected to look like. If you can't find non-ribbed 5/8" hose with "GM" and the square on it, order #2000 from Paragon and cut it to the length you need. The 3/4" hose has four ribs and no GM I.D.
    • larry linkous
      John,
      no, I do not have a JG. I am not restoring this car to be judge, just to make it a clean driver and to have future knowledge if I do retore it for judging standard's. I did recently join NCRS just so I could justify the question's. Thank you and the members of this board for the information and all the help past and future!!
