Intake manifold / lifter galley baffle C3 - NCRS Discussion Boards
  • Mark #44888
    I've got my '70 L46 engine apart. The intake manifold had a stamped-steel lifter galley baffle riveted to the underside of the intake manifold. It was a giant repository for some burned, oily, crud.
    I need the four new steel pins (like a rivet) that hold it onto the bottom of the manifold. Does GM still make these pins? If not, I guess I will leave this piece off.
    Thanks - Mark
    • 43236
    Re: Intake manifold / lifter galley baffle C3
    Mark-----
    The drive pins are currently available under GM #10229247. Another option is to drill and tap the holes in the manifold for machine screws (as I recall, they are #8 or #10). Then, install the srews with Loctite.
    • Mark #44888
      Thank Joe - you're awesome !
