Positive Cable - NCRS Discussion Boards
Positive Cable
  • Kevin M.
    • November 1, 2000
    • 1271
    Positive Cable
    for 67 SB no A/C. I find Delco part number 4F22P on Delco site. Parts guy no help can't give me description or length or part number. The one that came off is 23" his book said 19". I can order 4F22P from him just want to make sure it fits.
    Thanks Kevin
    car on jack stands till I find out
  • Kevin M.
    • November 1, 2000
    • 1271
    Neg Cable
    4F22N? While I'm at it.
    Kevin
    • Kevin M.
      • November 1, 2000
      • 1271
      Special order
      even if these are the right part numbers they are superceded, but the original can be ordered from Lansing MI. two weeks.
      Kevin
        • 11651
        Re: Special order
        Kevin,
        Based on others I have seen, they are NOT configured like your originals. If you "need" to have the car moving ASAP, get a cheap one from Pep Boys, but order a repro from Lectric Limited or one of their dealers. Do not assume that it will look like your original just because the number matches. It is not!
        Patrick
        • Kevin M.
          • November 1, 2000
          • 1271
          Re: Special order
          Pat,
          Thanks I just wanted Delco replacements like the battery. But it looks like my trouble might not be cables still checking. Still going to order cables.
          Kevin
          • William C.
            • May 31, 1975
            • 6037
            Re: Special order
            The original '63-68 spring ring design was superceded in 1969 (or 70, CRS disease) and all subsequent replacments were of the new design with the wider flange and the overstress protection built in. The early design made it too easy for mechanics to compress the spring WAY too much, causing permanent deformation and eventually a loose connection.
            Bill Clupper #618
            • Kevin M.
              • November 1, 2000
              • 1271
              Re: Special order
              My positive is an old replacement labeled Delco and another word I think Packard, my negative is original. I'm not worried about judging just wanted something Delco in #2 and close to original length.
              Kevin
              • William C.
                • May 31, 1975
                • 6037
                Re: Special order
                Originals were generally 4 ga except the copper clad aluminum versions in the '70s, those were 2 ga to make up for the difference in conductivity between copper and aluminum.
                Bill Clupper #618
