1961 windshield removal - NCRS Discussion Boards
  • Gary A.
    • May 31, 2001
    • 165
    I need to remove the assembly on my 61. I have laid under the dash about a hundred times this week and have finally gotten up the nerve. I would appreciate a quick run through on disassembly. I assume the whole assembly should lift off after the removal of the end post nuts and t-bolts. Gary
  • Art B.
    • 333
    Re: 1961 windshield removal
    There are about a dozen nuts to remove in order to get the windshield frame off.
    Some are a little hard to get at.
    • Roy B.
      • February 1, 1975
      • 7044
      Correct with a little bump of you hands at the top header to brake it loose
      • Dennis A.
        • April 30, 1999
        • 1010
        Remove the nuts/washers from the "T' bolts...Remove the Kick-Panels...reach up inside the square cut-out under the dash pad,using a universal joint wrapped in tape (or a flexible 1/4" socket driver) and remove the 2) 1/2" nuts each side.
        The windshield frame assembly is ready to remove. The (8) 7/16 "T" bolts are mounted with wire harness clips...keep track of them.
        Best to check out if the windshield lower tabs have been welded...if not have them welded before you reassemble.
        Good Luck
        • Gary A.
          • May 31, 2001
          • 165
          Thanks guys I'll let you know how it turns out. Gary
