67 grille fit - NCRS Discussion Boards
67 grille fit
  • Randy R.
    • March 1, 1983
    • 477
    67 grille fit
    Would someone be kind enough to measure the distance between the leading edge of the lower valance panel and the front edge of the grille? I would like two measurements, one by each mounting bracket. This measurement is about 1/4 inch more on the left side than the right side on my car and I don't know what is correct. I can not find this information in the factory assembly manual.
    Thank you.
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: 67 grille fit
    My 67 grille (original) lines up flush with the leading edge of the valance (non-molested). I placed a straight edge against both edges and it is in a vertical plane. Sounds like you have some alignment problems.
    • Randy R.
      • March 1, 1983
      • 477
      Re: 67 grille fit
      Steve,
      Thank you for the reply. I do have alignment problems. The door gaps are fine. The headlights and the hood fit well, the grille doesn't.
      Randy
