c-1 engine date code - NCRS Discussion Boards
  • Greg Pic 39571
    Looking at my date code on my 1957 block it reads C47, the numbers on my pad read F307EG, is it possible that this engine was cast then used this quickly after the build date
    • May 31, 1974
    • 8396
    Re: c-1 engine date code
    no problem with close proximity of casting date and machine assembly date. mike
    • Edward McComas
      I recall one engine that was cast and machined on the same day. Have seen many that were one day apart.
      • Greg Pic 39571
        Re: c-1 engine over spray
        putting my 1957 2x4 engine together, the intake manifold how much if any over spray should be on the alum. manifold, and bolts. The exhaust manifold how much over spray on it and surrounding bolts and french locks thanks in advance
